Home Forum Ask A Member Scott Atwater Bearing Equivalents
  • #272902
    seakaye12
      Hello….Does anyone have a list of Bearing Equivalents to Scott Atwater Part Numbers?
      For Example….The Roller and Needle Bearings in a 1956 16HP Lower Unit?
      3965-3148
      3965-3160
      3965-3105
      3965-3106
      3645-5112  (O-Ring)
      #272929
        I’m not positive but you might have answered your own question.
        The 31xx numbers in the S/A part numbers are standard bearing numbers. If you Google those part numbers, you should be able to get the dimensions of each one for comparison to your originals.
        Not sure about the O ring P/N but you should be able to match it up at your favorite auto supply.
