Home Forum Ask A Member Scott Atwater Impeller
Viewing 10 posts - 1 through 10 (of 21 total)
  • #6490
    brian
      I ran across this inexpensive, readily available Honda impeller that is supposed to fit the Scott Atwater Bail-A-Matic 7.5hp. Just passing along the info. Curious to find out if it works:
      Honda 4-stroke 8hp 9.9hp BF8D BF9.9D
      19210-ZW9-013
      Number of Blades: 6
      Plastic Hub
      Height: 14.77mm
      External Impeller Overall Diameter: 45.04mm
      Internal Shaft Insert Diameter: 13.35mm
      #53992
        I’m sure a lot of us would like to learn how it works out
        for you, let us know! I have a couple of B-A-M’s on
        my "to-do" list! Thanks.
        brian
          I don’t have any of SA motors. Found the information and wanted to pass it along.
          #53996
          seakaye12
            that has been mentioned on the board before.
            viewtopic.php?t=7602
            https://www.youtube.com/watch?v=7d1KWE6XDJo
            #53998
            Randy in Tampa
              can you find one to match with the Mercury KE4 or KE7? 🙂
              #54001
              Rich Cerankowski
                I sell plenty of KE4, KE7 at meets and ebay, Big Rich
                #54007
                bsplit
                  I’ve purchased from Big Rich…..fair prices and good to work with……he sent the wrong impeller by mistake, and immediately sent the correct one. I didn’t have to wait.
                  #54020
                  Randy in Tampa
                    Rich, I met you at Lake shipp 50 year anniversary meet, guess I’ll have to contact you when I’m ready to work on,… A hate to mention it ……the Darkside …..my ..um…Mercurys 😎
                    #54021
                    brian
                      Impellers listed for sale on amazon show the dimensions. There are numerous impellers there. I have no connection with Amazon, just happened to notice the details while looking for other items.
                      #54022
                        Looking at a chart I have, the Honda impeller (Sierra 18-3100) should be a six blade and measure 45 mm across, 14 mm thick and fit a 13 mm shaft. That’s about 1.8" across, 0.55" thick and 0.51" for the shaft size.
                        I heard years ago about using a Honda impeller but have never come across one even close to fitting the bailer motors. I’ll be going by a dealer later today so I’ll bring an old SA impeller along for comparison.
