Home Forum Ask A Member Scotty 16HP won’t pump water. I need help
  • #280027
    huntleybill
      I’m trying to get this motor to pump water. So far, I have checked both impellers and they are still flexible. I don’t know how long they have been in the motor as the owner says it has been sitting for years. I have blown air through all the tubes and they are clear. I have replaced the old and crumbling rubber seals on the water tubes.
      I took the power head off and put the lower unit in a 55 gallon barrel filled with water. With a drill I spun the shaft and there is no water being pumped up through the tubes.
      Also, I have not been able to find replacement impellers 3965-5100. Where can I source these?
      Any advice as to how to get this pumping again would be appreciated. Thank you
      Bill
      #280029
        Is the pump just under the powerhead? If so, the water level must be close to the pump it self.
        #280030
        huntleybill
          Yes, the pump is just below the power head. I tried lowering the lower end deeper in the water but that didn’t help at all.
          #280033
          huntleybill
            UPDATE: ok..I tried again and submersed the lower unit until the water was about 1 inch below the pump. i spun the shaft again with my drill. It started pumping water like crazy.
            I really don’t get how that is supposed to work when the motor is on a boat. The water level does not typically get that high (or should I say the boat does not typically sit that far dawn in the water).
            #280036
              that was there problem. move your body to the rear when starting.
              #280052
              huntleybill
                Yikes. No wonder they had problems.
                #280055
                reivertom
                  Those motors were notorious for pump problems.
                  #280059
                  Tom
                    You might want to check the grommet between the inlet of the pump and the tube up from the pickup.  A leak there would cause these symptoms.
                    T
                    #280111
                    seakaye12
                      There are people (including me) who have rigged up a priming bottle to squirt some soapy water in through the bailer port in an effort to get the blades wet and lubricated.  Usually when the motor starts I can increase the RPM just a bit for a few seconds and it will start pumping.  I’m sure that if everything was new this would not be necessary.
