Home Forum Ask A Member Screen filter cement.
  • #11008
    elgin2
      I`ve got a 5D10B Buccaneer that I need to fasten the screen filter into the tank fitting. Anyone have any recommendations? I was thinking a dab of JB Weld. Thanx.
      #81989
      jw-in-dixie
        Can it be soldered? Epoxy should work, or JBW. Good luck
        #81990
          Traditional is solder, but the last one I did, I used a couple of drops of Locktite threadlocker. Was very pleased.
          #81991
          lyks2tinkr
            I use just a dab of Damon Redkote tank sealer to hold them in place on all my square tank motors.
            Regular JB weld doesn’t hold up to gas well in my experience.
            #81993
            cajuncook1
              quote elgin2:
              What is the hole size of your brass screen ?
              Cajun
              #81998
              JOHN D.
                Super glue works. Just a very small amount though. That mesh wicks it right up.
                #82005
                jw-in-dixie
                  Thanks, John. I wondered about super Glue. Good to know. Cheers
                  #82006
                  cajuncook1
                    quote John C:
                    What brand super glue are you using? Does it hold up against ethanol or methanol?
                    #82025
                    JOHN D.
                      Just the cheap stuff.
