Home Forum Ask A Member Sea King 25hp crankshaft seal replacement
  • #2284
    brian-grigsby
      How hard is it to change crank seals on my 1957 Sea King 25hp? I’m more of a Merc guy. never done it on an OMC. I have the mag of right now to change coils. Should I change them while I have it down this far? I will NOT be using ethanol. Thanks, Brian.
      #22161
        Well if they are original I do. I have a large bag of them on hand though. I also have Franks tool, which makes it super easy.
        #22163
        brian-grigsby
          Thanks Chris. What is franks tool? Where can I check it out? Brian.
          #22166
            I once made a run of those on special orders, but am not planning on making any more. I gave my prints to Richard White. See a thread on the subject
            viewtopic.php?f=5&t=1450&p=11677#p11677
            #22168
            rjoynt
              Frank, can you post pictures of the tool?
              Thanks!!
              #22170
                brian-grigsby
                  That looks slick Frank! Does it pull, or install the seals?
                  #22175
                  wedgie
                    I’m still kicking myself for not buying one. 😥
                    #22180
                      Me to. I’m running low on deck screws.
                      #22186
                        quote Brian Grigsby:
                        It screws into the seal and pulls it out. Picture is a seal that was pulled out, still on the puller nose.
