Home Forum Ask A Member Sealing JW gear case
  • #275978
    billy-t
      Good Morning
      Been a little while since I sealed the last one. Cant remember if I am to put 3m-847 on the oring that is the prop bearing housing or not?
      Thanks for the help.
      BT
      #275979
        You shouldn’t really need to use the 847 on the oring, just a little light sealer.  Can’t hurt to use the 847 though, but it is messy, and dries very quickly, so the thing should be assembled immediately after sealer application.
        #276024
        billy-t
          Thanks Fleetwin
