Home › Forum › Ask A Member › seals and gaskets
Lower unit seals and Gaskets for a 12hp Scott mac. Where is the best place to buy these parts? Thanks. Charles
Good to see you back on the boards Charles !
http://www.laingsoutboards.com/scottmccullochparts.html
OOPS, Sorry . I see the lu seal kit is NLA. š³
It’s good to be back, somebody out there must know of a source for these scotts.
Looking at the parts diagram, I sorta understand. Aside from the prop shaft seal, I only see grease plug seals and maybe a shift fork extension seal.
Not a whole lot there…
What about a seal for the driveshaft?
I can find old Sierra numbers, 18-2108 for the prop shaft seal and -2109 for the upper drive shaft seal…But it seems both of those numbers are used for something else these days. Still trying to find dimensions for those seals..
When you opt to āRemember Meā, WordPress will tell your browser to save the state of pages when you navigate away from them. This allows them to be restored instantly when you use the back and forward buttons in your browser.
OK
