Home Forum Ask A Member SEARCH FOR REALLY SMALL SCREWS
  • #5777
      Anyone have a source for really small screws to attach small tags to things. Bolt Depo has no. 4 slotted machine screws but I think they are too big.
        4-40 is as small as I can find anywhere. I use them for carb butterflies. Any smaller and I’d be going to a watch repair shop.
        #48085
        RICHARD A. WHITE
          You could obtain ones called "drive" screws, commonly used on outboards to affix the ID tags…
          classicomctools@gmail.com
          #48089
          JOSEPH BRINCAT
            visit any good model hobby shop, sizes down to #0
            #48091
            ROBERT LAFAYETTE
              Joe is correct, any good hobby shop should have what your looking for.
              At the Toledo Weak Signals hobby show one of the venders is
              "RTL Fasteners" and they have a wide variety and good prices,
              They also have a lot of stainless hardware etc.. 😎
              http://www.rtlfasteners.com/
              Good Luck,
              amuller
                RTL carries even sizes 0,2,4 and up.
                If you need odd sizes 1,3,5 and so on you could try Fastenall.
                #48125
                George Emmanuel
                  Bob,
                  Ace hardware sometimes carries a #2 screw. You might have to tap the hole. If you use a #2 tap, use extreme caution because it can snap off easily. Make sure you use a thread-cutting lubricant and don’t take long turns.
                  George
                  #48130
                  oltimer
                    quote George Emmanuel:
                    Bob,
                    George
                    Very true words spoken there George. In all my years in the shop; we only purchased Butterfields. Cheap taps are very brittle, especially in those very small sizes.
                    #48133
                      The OMC drive screw is 0301992 – They were two for a nickel in 1952.
                      #48135
                        quote Garry in Tampa:
                        $2.50 a piece now! 😯
                        I’m sure there’s a small fortune worth of them hiding in the dark corners out in the garage!
                        http://www.marineengine.com/newparts/pa … um=0301992
