Home Forum Ask A Member search instructions
  • #254340
    HARRY D. NICHOLSON
      How can this site be searched by topic successfully ?
      #254341
      Hugh Davis
        harry,
        I’ve had some difficulties searching but if you try several key words , you should end up getting to where you need to be.
        you may need to try a couple times.
        I’m a newbie so maybe I’m doing it wrong but scrolling thru a thousand entries is not something I can entertain( IT WILL PROBABLY BE ENTERTAINING!)
        #254344
        Pondrocket
        Keymaster
          outboardnut
            . I do not use the search bar in the upper right. That search bar only searches the site. This is how I do a search for past posts.
            I press on “members only”
            Press on “active members forum”
            Fill in “enter keywords “
            #254401
            HARRY D. NICHOLSON
              Thanks to helpful aomci members, I now know the secret of searching this site successfully, instead of receiving the message of “NOTHING FOUND” every time.  Member since 1984.
