Home Forum Ask A Member SEARS 14.1 MODEL 574-59760
  • #201532
    machparts
      I HAVE AN OLD SEARS 14.1 MODEL 574-59760 SER# 68601410-1994 . RUNS WELL AT SPEED BUT IDLE’S ROUGH AND HARD TO START. ANY TUNE UP PARTS STILL AVAILABLE FOR THIS ?
      CARB KIT, WIRES AND PLUGS, ETC..
      #201538
        seakaye12
          The 574 Prefix Sears Engines were made by McCulloch. In addition to Laings you can try discount marine parts in Wisconsin. All you may need is a good basic tune-up….clean and adjust the points, clean or replace the plugs, take the carb off and give it a thorough cleaning. You may need a bowl gasket to do that or you may well be able to re-use the one on there.
          http://discount-marine-parts.com/ob_elgin_mcculloch_model.html
          That’s a good motor; I wish it were mine LOL!
          #201558
          Tom
            If it was run lean by the previous owner the reeds may be burned. Had this happen to a similar motorwhen I was a kid. So if a time up, including new condensers doesn’t help, consider checking the reeds.
            T
