Home Forum Ask A Member Sears/McCulloch 7.5 hp outboard connections for kill switch wiring on mag plate
  • #297084
    To All,
    Like the dummy that I am, I did not take a picture of the mag plate before disconnection of the wiring for all items on the mag plate.  I guess that one kill switch wire connection goes to the points connection with condenser and coil…and the other to ground on the mag plate.  Please confirm if you will.
    the repairs are going well except I still need some parts to try to start the motor.
    Thanks for the help.
    #297097
    seakaye12
      That should do it;  or just shut down with the choke.
      Shutting down with the choke is preferable on the early versions of electronic ignition….which I realize that’s not what you have.
      #297099
      Thank you seakay12 for the confirmation.
      DickS
