Home Forum Ask A Member Seizef piston in 1936 Johnson 100
  • #246289
    Herman Powers
      I unbolted head and piston is seized in head.What s the best thing to do?
      #246300
      lloyd
        Not sure if you meant to say the piston is seized in the cylinder or seized in the head. In either case heat and vibration and penetrating oil should help. Hot water to heat things up and tapping with tools for vibration.
        #246301
        Herman Powers
          Thanks
          #246315
            round wooden peg and a hammer (alternating on the pistions if more than one) worked for me. WD40 helps . took a week to free up a 9.5HP
            #246317
              Above all, patience is your best friend. The motor didn’t get stuck like it is in just a few days, so likely it won’t free up very quickly either. Heat, cooling, lots of penetrating oil and as crosbyman noted, a wooden peg and hammer on the piston should eventually get it freed up.
              #246328
              Herman Powers
                It being a Model 100,the spark plug is in the side of head and not directly over piston.This makes it difficult .It is tough tapping on the bottom side of piston where rod connects.What y’all think?
                #246347
                  looked at pics of a mdl 100…..bummer no cyl head to open up not to many options 🙁
                  • This reply was modified 4 years, 6 months ago by JACQUES.
                  #246352
                  stanley
                    A grease gun and fitting for the plug hole may be your only option.If you can get the cap off of the connecting rod,and the crank out of the way,sometimes you can pull a seized piston.
                    #246355
                    Herman Powers
                      Thanks guys.I will keep on trying to get it loose
                      #246359
                        Not to be a “Debbie Downer”, but you might want to look for a parts engine that
                        turns over with compression. Of the few outboards that were froze hard,
                        but I eventually got apart, maybe one or two turned into “runners”, and
                        not “great” runners. It seems that the smaller the cylinder bore, the more critical
                        good compression becomes.
                        Maybe others have had better luck.
                        Not to say it’s not worth trying, but it’s always good to have a back-up plan.
