Home Forum Ask A Member Serial number tags
  • #2464
    Rob
      Hi everyone,
      I am just about to the finish line of my first restoration. I drilled the rivets out of the serial number tag and I would like to rivet it back in place when I am done.
      I’ve used ‘pop rivets’ before but never actual rivets. So, how do you do it and where do you get them? Is there a kit that I can buy?
      Thanks for taking the time to read my post and lend some advise!
      Rob
      Rob
      #23324
      jpatti75
        Perhaps some will chime in and confirm the size and that these will work, but McMaster-Carr has just about every kind of fastener you can think of:
        http://www.mcmaster.com/#standard-rivets/=yti0u0
        JP
        #23325
          They are called "Drive Screws" http://www.mcmaster.com/#drive-screws/=ytinkz
          In the future, instead of drilling them out, IF the hole goes all the way through, you can punch them out from the rear and re-use them. I have also removed them by hacksawing a slot in the head and twist it out with a screwdriver.
          #23330
          Rob
            That’s perfect!! Thanks, guys!!
            One more question if you don’t mind; How do you determine the correct size/shank diameter?
            Thanks again!!
            Rob
            Rob
            #23385
              That would depend on the size drill you used to drill them out.
              #23394
              wiscoboater
                Tapping them out from the back side with a very small punch ( I use a carpenters nail set ) works great. I have always been able to tap them back in when done with the motor. For that I use a small tack hammer. Never had to replace one because of damage doing it like that.
