Home Forum Ask A Member Severe Back Fire
  • #59662
      quote fleetwin:
      Are you sure the plug wires are on the correct plugs? Just swap them around and try it, will only take a few minutes
      Listen to Fleetwin. 99.999% of the time, the symptom you describe is cause by crossed wires and is dirt easy to both make the mistake and to correct.
      #59669
      fry-cook
        Thanks, Haven’t spent anytime on it lately… Darn job is getting in the way. How would I know if the Carb is synced to the Magneto? Father’s day will be me time.
        #59682
          I question your use of the term "back Fire". This is usually a sneeze into the carboretor caused by switched spark plug wires or a lean mixture. Firing with the ports open (switched wires) would not strain the starter. However if the safety interlock were compromised, it would allow over advancing the ignition which would fire the ignition early and try to run the outboard backwards. This would put enough force on the bendex drive to shear off the cotter pin or break the starter motor mount. Lucky the cotter pin went and not the motor mount. . . 😮
          #59684
            This should be close to what you have, check page 8, number 43 . . . 🙂
            The OMC standard magneto . . .
