Home Forum Ask A Member shift rod O ring
  • #230640
    GLEN DEUTSCH
      Think I found the right shift rod O- ring. It’s metric. The O-Ring store 4.5mmx6mm Buna-n-70. They are a bit snug in the hole in the lower unit. I put the shift rod in the hole and slide the greased O ring over the rod . Then tease the ring into the hole, followed by the bushing. Then tap the bushing tight . I have a bunch If you send me a PM, I can send you a few. Or go to The O-Ring store. They are very cheap. I have only tried it on a few motors, but they all tested 15psi/15sec. Worth a try
      • This topic was modified 5 years, 1 month ago by GLEN DEUTSCH.
      #230843
        Do you have the part number or a link?
        #230968
        GLEN DEUTSCH
          I don’t, but the O-Ring store is easy to navigate. Go to the metric section and follow along. I will go into their site and see if I can get a number for you
          #230970
          GLEN DEUTSCH
            Mumbles,
            Go to the web site. Click on Buna-n-Nitrile (NBR) metric o-rings 70 durometer. Scroll down the green numbers to 4.5mmcs x 6mm. $0.26 each. It’s the first item
            #230980
            Evinrude 25
              https://www.theoringstore.com/store/index.php?main_page=product_info&cPath=368_12_482&products_id=17404
              The OD=15 mm x ID= 6 mm x 4.5 mm thick.
              Capture
              • This reply was modified 5 years ago by Mumbles.
              #230987
                Thanks guys.
                #230988
                Evinrude 25
                  Shipping is $6.99 to USA but it does not ship to Canada.
                  #230995
                  GLEN DEUTSCH
                    That”s it
                    #230996
                    GLEN DEUTSCH
                      Evinrude 25,
                      Send me a PM with address and I will send you a bunch
