Home Forum Ask A Member Shift shaft o-ring plug
  • #4896
    RICHARD A. WHITE
      Resealing a gear case that had some issues, I have one leak. It leaks around the outside of the brass plug that holds the shift shaft o-ring.. Thoughts on something to seal that? For what are obvious to me reason I do not want a permanent seal so that should the next guy, (possible me), would need to be able to get it out..
      So what can I use…???
      classicomctools@gmail.com
      #41429
        I put a ring of 3M 847 around the circ of the brass before I tap it in.
        #41430
        RICHARD A. WHITE
          Well that is nice, but it is already assembled, and no leaks but there…some paint around the edges?
          #41431
          wedgie
            Try tapping it down a bit further to compress the o ring a bit more.
            #41432
            RICHARD A. WHITE
              I seated it pretty good the first time, then got serious after finding the leak, it won’t go any further south…going to try some paint….
              #41433
                I don’t envision paint would last very long in that environment on that surface. Strange leak. What motor is it?
                #41434
                RICHARD A. WHITE
                  OMC 72 18 hp…
                  #41440
                  fisherman6
                    I have trouble seeing paint doing it in that environment as well. You don’t have anything to loose by trying it though. I would be more apt to think some kind of gasket maker would stand a better chance in there. Maybe try the paint first and if it gives up try something like form-a-gasket applied around the top of the bushing. Not sure if that will work either but it’s something else to try.
                    The last gearcase I re sealed was on my ’62 Johnson 5.5. It leaked at the shift rod o-ring and around the bushing as well as prop shaft seal, drive shaft seal around the shafts and the seal bores, the vent plug washer and the drain plug washer. The only thing that didn’t leak was the spaghetti seal. Everything got a good dose of 847 on that one. It’s good now but after that one, everything will always get coated with sealant when resealing a gearcase. It leaked everywhere. With about 6psi in the gearcase there were bubbles coming from places I never thought about having leaks.
                    -Ben
                    OldJohnnyRude on YouTube
                    #41443
                    RICK EICHRODT
                      Did you install or replace the gasket that goes in first? First the gasket, then o-ring and finally the brass bushing. Part number 304764 should be the part you need. I also believe that the brass bushing has a recess area where the o-ring sits. The smaller motors just use the o-ring and bushing, no gasket.
                      http://www.marineengine.com/parts/johns … n=Gearcase
                      #41445
                        Degrease it and apply a light coat of your favorite epoxy to it. I’ve had to do this on salty motors and it will break off if you need to remove the bushing. A bit of green Loc Tite bearing retainer on it before assembling would be better though.
