Home › Forum › Ask A Member › Shop Tools/Machine Questions
- This topic has 9 replies, 8 voices, and was last updated 5 years, 9 months ago by
Tubs.
May 6, 2020 at 8:58 am #202167
Hey Guys,
I am thinking about getting some new tools for the shop. What size arbor press do you use? I’m thinking in terms of height/clearance and PSI (or however they measure pressure). Same thing regarding drill press, what would be a good clearance? Any other hints/tips greatly appreciated.
Thanks!
May 6, 2020 at 12:50 pm #202207I’d go with a hydraulic press instead of an arbor press as they are more versatile. I built one using a 12 ton jack and it’s one of the handiest tools I have. Harbor Freight might have some cheap ones for home use.
May 6, 2020 at 1:04 pm #202208Some year back I purchased a HF 12 ton press when it was on sale.
I believe I paid about $90, currently on sale for $120 with coupon.
Good value for the money, but, not industrial tough,
At one point I thought it needed repair, I was not able to find either
parts or a manual. Fortunately, no repair was required.
I have a floor jack (K Mart brand) that does need repair and
same story there.
I do not know if it is a liability issue or if extending service life is not a
consideration. Unless you make it yourself ,I doubt there is a
Made in USA press priced within a decimal point of HF or other
brands made in Asia.
The 12 ton is too tall to be on a bench and a stoop when set up
on floor. Mine is in basement, a shop with a high floor to ceiling distance would allow bench mountiRTR
:Foot Print of HF 12 ton press is 20″x20″ x54″ tall.
If mounted on a platform the working area could be at a
more comfortable lever. I have not done so.
Import bench top drill press from Lowe[s has proven
adequate and price was modest.
Off shore home shop machinery is usually adequate
in my experience,if used within their limits-
This reply was modified 5 years, 9 months ago by
green-thumbs.
green-thumbs.
May 7, 2020 at 7:58 am #202327I work on a lot of stuff besides outboards, so here are some things I have in my shop – YMMV :
Arbor Press – 3 ton vintage Dake – Anything smaller than the 3 ton size doesn’t have enough clearance, I think.
Hydraulic Press – HF 20 ton – This is an OK , pretty powerful (but slow) press, but you have to be willing to “modify” it a bit to get the best result – Much good on-line info – Make sure you get a newer one, with the cut steel arbor plates, NOT the old style with the cast ones – The stores may possibly have both kinds.
Drill Press – I have a couple, but most often use an older Atlas 15″ floor model – I think a 15″ drill press is about the smallest one practical, as long as you have the floor space. It’s tempting to get a smaller bench model, but you lose valuable bench space, and something is always “in the way”, when you want to use it
May 7, 2020 at 9:19 am #202337I have an old Taiwanese 5-speed drill press. It’s junk. Be careful what you buy. I seldom use the drill press anyway, because I now have a mill.
May 7, 2020 at 11:00 am #202356Thanks for all of the info guys. A lot to think about!!
May 7, 2020 at 11:46 am #202360I used a mill working at TRW. Difference between night & day from a press.
May 7, 2020 at 9:53 pm #202452
May 8, 2020 at 8:51 am #202472Yup Tubs! Poor mans press! I can relate to that!
dale
Water going over a fall. Is it pushed or pulled?
May 8, 2020 at 10:10 am #202488
