Home Forum Ask A Member Spark Plug
  • #226976
    yooperrigged
      Hello,
      Will it be ok to use a J6C plug in a 1968 Johnson SC10S? I know it calls for a J4c. I am just checking. TIA
      Yooperrigged
      #226979
        The J4C is a bit colder than the J6C but if the motor is getting worn out a bit and getting low on compression after all these years, the hotter J6C should be OK. It’s best to remove the new plug after running it a for a while and read it to see if it’s burning OK.
        #226986
        yooperrigged
          Ok, thanks Mumbles. I have a J6C on hand currently, but I will order a J4C as well. I guess there is no rush since the ice is 10 inches thick. 😎
          #227133
          outbdnut2
            If you plan on slow trolling for hours at a time the J6C will probably stay cleaner.
