Home Forum Ask A Member Spark plug
  • #239334
    james hobson
      My 57 7.5 uses a J6J spark plug I want to run a hotter plug what spark plug can I run one or two steps hotter also any harm in doing so.
      #239359
        NGK B6S is equivalent to the old J6J which has been replaced by the J6C. I don’t think NGK makes anything hotter in that style and if they did, it would be a B4S. Champion J8C would be the next hotter plug up from the J6C.
        If your motor needs hotter plugs, you should try and find out why. If it is trolled a lot or the carb is adjusted too rich, then a hotter plug will be required. Running way too hot of a plug can cause pistons to melt but you should be OK with the J8C’s.
