Home Forum Ask A Member Spark plug for Martin 200
  • #3835
    Rich Cerankowski
      What is the correct spark plug used on the Martin 200 also the gap. Champion j3’s were removed from it. myoldoutboard@aol.com 7322673211 Thank you Rich
      #143781
      georgemartin200
        Rich: Depending on what you are using the motor to do. I run NOTHING but NGK B-6S, B7S, B8s. just different heat ranges for slow or fast running but rule of thumb, use B7S
        Ronald
        Tomahawk
        #144758
          Interesting question. My best info says it came with Champion J3 @ .030″ An old Champion book says J62R @ .023″. I’ve never heard of either of those. Better ask Russ Larson, the Martin guru.
