Home › Forum › Ask A Member › spark plug wires
- This topic has 10 replies, 6 voices, and was last updated 4 years, 4 months ago by
JACQUES.
November 6, 2021 at 9:02 pm #249265
I have to replace plug wires on a mid seventies 6 horse evinrude fisherman.What type of wire did they have ? I’m thinking just a solid wire core plug wire that I can buy at my local auto parts store ?
November 7, 2021 at 12:02 am #249271I use these.. not to expensive considering 8 + 1 wires come with boots , ample long for the job heat resistant silicone solid core 7mm metallic wires
hopefully you can get them in the US … or equivalent wires
shorten the boots if to long for you
https://www.napacanada.com/en/p/BMX700175
Joining AOMCI has priviledges ๐
This reply was modified 4 years, 4 months ago by
JACQUES.
November 7, 2021 at 10:17 am #249286I use these solid core wires from Tractor Supply – get them online or maybe they have a store near you:
https://www.tractorsupply.com/tsc/product/tisco-spark-plug-wire-set-sws260?cm_vc=-100051 user thanked author for this post.
November 16, 2021 at 9:47 am #249762I just checked them out and they look like they should work. Thanks
November 16, 2021 at 2:19 pm #249772I use these.. not to expensive considering 8 + 1 wires come with boots , ample long for the job heat resistant silicone solid core 7mm metallic wires
JACQUES.
Yo crosbyman, the description for these wires says they are ‘Low Ohm Distributed Resistance Core’. Carbon core instead of solid core then?
November 16, 2021 at 5:45 pm #249788nope solid wires 0 ohms is the lowest they got so the statement is true
zoom in on the picture… solid wires may not be copper but 0 homs is 0 ohms across 18-24 inches of wire
๐
November 16, 2021 at 6:01 pm #249790OK, I see it now! Yup, solid core.
November 16, 2021 at 11:10 pm #249810Solid core wire is one wire inside the insulation. Stranded core wire has many strands for flexibility. Carbon core is no good for old motors.
November 16, 2021 at 11:53 pm #249811ok lets call it twisted multiple strand solid core wires with no carbon
JACQUES.
November 18, 2021 at 8:40 am #249845I buy my cable by the foot on eBay….7mm stranded (and that NAPA link above is stranded, not solid), and it’s cheaper than buying sets & cutting them up. This stuff works just fine…never had an issue
https://www.ebay.com/itm/172807569549
If you want to get all fancy, you can go colors:
https://www.ebay.com/itm/201967637890
https://www.ebay.com/itm/201043820656
https://www.ebay.com/itm/201099141462 -
