Home Forum Ask A Member Speed prop ID help
  • #8630
    squierka39
      I’ve got a Michigan "racing" prop, 2 blade bronze. It’s only marked with an E along with Michigan, then the size on the backside 7 1/8 x 8 3/4.
      It’s a right hand (clockwise) prop. Bore is 9/16", 1 3/4 front to back. Any ideas what it might fit?
      Thanks
      #67176
      mercuryman
        Mercury KE7 10 hp. The KF7 & KG7 have a 5/8 " bore. Could also fit Mercury KE4 7.5 hp It will fit these motors but may not be the right prop for them.
        #67178
        squierka39
          Mercian, that would be great on my KE7 if I wanted to go fast in reverse. Lol. This is a right hand prop, Merc is left spinner.
          #67196
          mercuryman
            OK I missed the righthand
            #67207
            squierka39
              I made a mistake, the props bore is for a 1/2" shaft. Sorry.
              #67280
              squierka39
                Here is a pic if this helps any.
