I started working on my $25 Speeditwin, 1948 model 6039. The flywheel on this one will likely need replacement. The key broke at some point and things got a bit loose by the looks of the hub and the crankshaft taper. I believe I can use the crank as is, but the flywheel is iffy at best.
Does anyone know what motors shared the same flywheel? I haven’t pulled the flywheel off my 1948 SpeediFour yet to see if they are the same. Externally they are identical, but underneath may be different. I will find out, but thought I would ask in case anyone knows. How about the BigFour? Just looking for options when it comes to finding a donor.
The flywheel had a toothed lockwasher under the nut, which I do not think was supposed to be there. I have not seen one on other period motors. Again, can anyone say yes or no?
The internals look pretty good. A little scorching, but no visible scoring of pistons/rings. It turns over freely now that I have got oil into all the moving parts. It was a bit stiff prior to that after sitting for who knows how long.
I am hopeful that this will be a runner once I get the flywheel issue sorted out.
