Home Forum Ask A Member Speeditwin lower unit grease
  • #6669
    bsplit
      Are there two screws in the lower for filling it with grease?…..I see one that says "grease", but don’t see a vent screw. The motor is model 6039, 22.5 hp Speeditwin.
      Thanks,
      Jim
      #55496
      david-bartlett
        Jim,
        Just the one screw. Use grease, not oil.
        #55504
        bsplit
          Thanks, Dave……what’s the procedure to fill the unit?
          #55505
            At least three gear cases were used on that 6039 model. There were also a couple after market gear cases used in "C" Service racing that didn’t have any grease plugs at all.
            They used the Stormboat Motor gear case after the war (World War Two)
            #55507
            david-bartlett
              I cheated. I had the lower apart, so when i put everything back together i filled it before i pit the gear housing cap back on.
              quote Bsplit:
              #55534
                This is what is meant by "Grease"
                #55581
                bsplit
                  I’ve been using both lubriplate 105 and corn head grease in my old motors.
                  Thanks,
                  Jim
