Home Forum Ask A Member Speeditwin Magneto
Viewing 7 posts - 21 through 27 (of 27 total)
  • #78275
    George Emmanuel
      Nice job! The original mag handle bolted on the underneath of the mag plate. The diagram Garry showed is for the later version but the principle is the same. The early one like yours has a tab on the advance lever and an insulated "button" ( more like a rivet with insulating washers around it) that the wire coming from the coil attached to such that when you depressed the tab it grounded the button thus killing the spark. The mag plate you have is the beginning of the transforming that changed from the 1920’s style to the 6039 Speeditwin.
      I love you creativity!
      George
      #78276
        Great looking restoration on the mag. Looking forward to seeing the finished motor!!
        1982 Evinrude 25hp
        #78281
          quote George Emmanuel:
          Nice job! The original mag handle bolted on the underneath of the mag plate. The diagram Garry showed is for the later version but the principle is the same. The early one like yours has a tab on the advance lever and an insulated “button” ( more like a rivet with insulating washers around it) that the wire coming from the coil attached to such that when you depressed the tab it grounded the button thus killing the spark. The mag plate you have is the beginning of the transforming that changed from the 1920’s style to the 6039 Speeditwin.
          George
          George, thanks for the information.
          I asked this a while back, but never heard any words of wisdom. Regarding my Speeditwin
          flywheel, I only have magnetism across one side of the shoes, as seen by the bolts.
          Is this normal / correct?
            Polish the hub where the breaker points ride, you don’t want them to pick up any dirt or rust as the flywheel slides on. This is easier if the woodruff key points away from the points. Pushing against the taper while you line up the key gives more room for the contact point . . . 😀
            #78301
              I’ll be sure to clean up the flywheel and points cam nice and shiny
              before it goes together. I wonder is sandblasting the inside of
              the flywheel would take away the magnetism of the magnets?
              I’ve never tried yet.
              George Emmanuel
                I wouldn’t recommend sandblasting. Bead blasting maybe, but tape off the cam and the bore of the hub. Regarding the magnets, I’ve never seen that before either. Find someone who will recharge the magnets, but make sure they know what they are doing. Experimenting down here with recharging indicates the polarity affects the spark. Steve Wood is good with it. He might be at Tomahawk this year and usually has his charger with him. I have extra flywheels if you need one.
                George
                #78443
                  George, thanks for your input. I do have a homemade magnet charger.
                  Not sure I know what I’m doing half the time though, so I’ll have to
                  "measure twice, cut once", or something to that effect!
                  I do know it takes a little "backwards thinking" and a compass
                  to get the flywheel set up correctly for charging.
                  Currently, I don’t have curved blocks for charging flywheels,
                  but this may finally give me the urging to make some.
