Home Forum Ask A Member split pin, cotter pin – source
  • #5984
    jiall2
      Are cotter pins , the small ones for carb linkage, available at any auto part stores or hardware stores or anywhere else ? Thanks for any help!
      #49906
      johnny-infl
        I made some out of thin brass wire that works perfectly.
        I guess thin stainless safety wire would also work.
        I have seen the very small cotter pins at Tractor Supply and Lowe’s.
        Edit: I bought these at Lowe’s today = 3 for 58 cents.
        #49907
          mcmaster.com has cotter pins down to 3/64" (0.047"). But even those are too large for most old outboard carb linkages. They used wire for that application. Rip open an old coil and salvage the primary winding for a big supply of nice enamel coated copper wire.
          #49934
          elgin2
            I found them at a farm supply store.
            #49935
            donsmarine
              sometimes 1/2 of a small cotter pin will work or larger size of s/s fishing wire
