Home › Forum › Ask A Member › Spring Ignition Terminal
- This topic has 7 replies, 6 voices, and was last updated 7 years, 6 months ago by
mr-asa.
September 12, 2018 at 7:16 pm #11184
What is a good source for the spark plug spring ignition terminal used on 50’s OMC motors P/N 510231?
Thanks,
NickSeptember 12, 2018 at 7:42 pm #82737Usually get mine along with other parts at Marine Engine.
http://www.marineengine.com/newparts/pa … num=510231
"Every time you remove a broken or seized bolt an angel gets his wings."September 12, 2018 at 8:24 pm #82740$4.09 each….WOW
classicomctools@gmail.comSeptember 12, 2018 at 8:38 pm #82742Yeah, I’m sure there’s a cheaper source somewhere. Anybody knows, pass it on. I only get them at ME since I’m usually ordering a bunch of other parts at the same time.
"Every time you remove a broken or seized bolt an angel gets his wings."September 12, 2018 at 8:42 pm #82744Yeah, that is why I asked. I thought the price was a bit high for a piece of wound wire. Got to be a source at a more reasonable price.
September 12, 2018 at 8:45 pm #82745I got some a while back for a chain saw on ePay. The rubber part was smaller but the spring piece was fine. They were about $2 each as I recall.
September 12, 2018 at 10:00 pm #8275025% discount for OMC
http://www.duskyonline.com/mm5/merchant … reen=SRCH2September 12, 2018 at 10:30 pm #82753quote bobw:Yeah, I’m sure there’s a cheaper source somewhere. Anybody knows, pass it on. I only get them at ME since I’m usually ordering a bunch of other parts at the same time.Not the exact same style, however these are a bag of terminals
https://smile.amazon.com/TAYLOR-CABLE-4 … 00ZPJ1CFI/Found these
https://smile.amazon.com/Stens-135-053- … 001OKBG5I/
