Home › Forum › Ask A Member › Spun Prop hub.
- This topic has 8 replies, 6 voices, and was last updated 5 years, 8 months ago by
bill-mcnamara.
July 5, 2020 at 10:56 pm #207874
I was out for a cruise yesterday with my Twin ’56 Javelins.
After about 2 hrs, one engine revs up significantly.
Quickly throttle back, I find that each engine shifts into forward and reverse smoothly, and each one provides thrust at idle and slow throttle.However upon throttling up a little, the port engine proves to be the guilty one.
Proceeded home “on one” ( the beauty of running 2 engines) And pulled the boat onto its trailer. Over night I get the idea that maybe the prop may have separated from its hub, although I have never had this problem in my many years of messing around in boats.
Pulled the left frop this afternoon and immediatly notice the hub has come back tightly against the shear pin, and the gap to the gearcase looks a little wider. The pin was so snug against the hub, that I had to tap it out with a drift.
Sliding the prop off, and flipping it over pretty much convinced me that I was on the correct path.I’ll try to add some pics. The hub had shifted/slipped to the right in the last pic.
I slipped on a spare prop but have yet to give it a try out on the Lake, but I’m confident that we’re all set for more boating.
Never too old to learn something new, and it’s what makes our hobby so much fun.
Bill.
July 5, 2020 at 11:37 pm #207879Is this a question or an observation? It would seem to be an observation, and you have located the trouble, right? From my viewpoint, yes the hub is spun.
July 6, 2020 at 7:09 am #207887what a beautiful rig
July 6, 2020 at 7:53 am #207890
This reply was modified 5 years ago by
Tubs.
July 6, 2020 at 8:07 am #207892Just some ramblings Frank, after a nice day on the water and an easily solved glitch.
July 6, 2020 at 8:24 am #207894Ramble on (with a spare prop).
GJMGP
July 6, 2020 at 8:41 am #207895Thanks Fleetwin and Tubs, I’m enjoying he results of a being able to save a nice old cedarstrip boat from the burn pile!
Bill.July 6, 2020 at 10:51 pm #207966Holy-sha-molie that is a perrrty outfit! I bet those 30’s push her along kinda quickly!
nice job
daleJuly 7, 2020 at 8:00 am #207970Thanks Dale, the boat was a fun and rewarding project.
It needed 55 new steam bent ribs, new inner and outer gunwale strips,3 new inner stringers and outer keel strips. The seats were missing too.The cedar hull itself was fine, as was the mahogany transom and decks. The decks had been “attacked” with a belt sander by a previous owner, and required so much faring that I had to caulk between the planks which was not an original feature on this particular boat.
