Home Forum Ask A Member Spun Propeller Hub
  • #182491
    outboardboy3
      I have a 1957 Johnson 35hp Outboard that I have used this entire summer without any problems, but the other day I spun the hub inside the propeller. I took it off and found that the rubber had shredded that was pressed inside. Does anyone know of someone who can rebuild it for me? I have another prop that I am using currently, but would like to keep it original. Thanks
      #182495
        Any good prop shop should be able take care of you. Being in Michigan, Michigan Wheel did ours.
        #182505
        Doug Wilson
          Not sure where you are but Indy Prop Shop in Indianapolis, IN (indypropshop.com) does great work and has done two props for me
          Doug
          Doug
          turned off?
          #182519
          lindy46
            Many dealers can send them out and have them re-hubbed.
