Home Forum Ask A Member Stalling 1965 Merc 39
  • #77748
      mine doing the same thing till I raised up the fuel tank and put it on the back seat next to the engine and it stopped dying
      that’s how I used it after but never dug in and get around to check out the fuel pump….I moved on to a 9.5 as my troller and back up engine.
      I suspect the pump was weak somehow and could not lift the gas so I am likely due to change the diaphragm
      also… do check for air leaks in that silly little connector and ensure the tank vent is clean
      I
      #77764
      david-bartlett
        I had a 9.8hp of the same vintage that would do the same thing. One of the check valves in the fuel pump was stuck, so it would not pump well, and these pumps are small to start with. Ran great with the tank up high. Unsticking the check valve fixed my issue.
        #77767
          convert to the latter larger pump like merc recommended back then. problem full fix.
          #77820
          enrico-italy
            I had the same problem on a 1970 Merc 40.
            After 20 mins or so, the motor stalls… often it don’t stop completely, but it runs "rougly" as flooding.
            Checked many times the carb and fuel pump, I finally find the problem was the under flywheel coil… or, better, the cable connection into the coil.
