Home › Forum › Ask A Member › Stripped mag plate FD-11
- This topic has 13 replies, 8 voices, and was last updated 8 years, 9 months ago by
retiredoz.
June 18, 2017 at 7:58 pm #7367June 18, 2017 at 8:14 pm #59890
Use my FI (faux ignition) module.
Ken
June 18, 2017 at 8:41 pm #59891Tap it out to the next size up if you can’t find a replacement. You should be able to find a replacement fairly easily though.
June 18, 2017 at 8:43 pm #59892Small bolt ?? with a locking nylon nut on top maybe
June 18, 2017 at 8:51 pm #59893Put a bolt in from the bottom, epoxy it in,
and use a nut to hold the points. Lot’s of options!Prepare to be boarded!
June 18, 2017 at 9:03 pm #59894quote Ken W:Use my FI (faux ignition) module.Ken
What is that?
June 18, 2017 at 9:15 pm #59895Copy of the Red Atom ign. I need more testing. Send me your address in a PM. (Free set).
Ken
June 18, 2017 at 9:32 pm #59899Indeed, thanks for the recommendations guys. I found a replacement plate from a donor motor. Guess now is a good time to go through it all and make it good throughout the mag.
Strange however, that the replacement plate has one small change. The FD-11 plate on the left has no hole (for the cut out switch?) while the other one does and the numbers cast into the plates are 580210-2 (FD-11) and the other one is 580210-2 D.
June 18, 2017 at 9:54 pm #59900Yup lots of plates that are pretty close, but not quite the same when the have a suffix letter after them. Gotta be careful on those sometimes!
Ken, I would like to try a couple out. Would rather pay for them though, send me a PM.
June 18, 2017 at 10:41 pm #59903Oftentimes, the numbers we find cast into parts is just a "casting number". There are some cases where the casting number is the same as the part number, such is the case for the FD11…But, when you look up the part number for the 1958 model with the stop switch, you find a completely different part number than 580210, even though your later model mag plate has this number stamped into it.
In both cases, the same basic "casting" is used, but there is an extra hole added for the 1958 models with the stop switch, which is why it has a different part number….
Oftentimes, the casting numbers we find on parts do not correlate with the part numbers in the parts book…. -
