Home Forum Ask A Member Stubborn bearing housing bolt 3hp Lightwin
  • #143413
    hmai
      Any suggestions on removing a stubborn bearing housing screw on a lightwin. Tried impact screwdriver and several good gits, some heat etc. Nothing is getting it to budge.
      #144636
        Heat and impact screwdriver are your best bet.
        #145124
          try screwing it IN a bit …then try OUT
          #149144
            funny thing happened this week….
            I was changing my son’s car to snow tires and one security bolt would not come off when whit a 3 foot extension bar
            All I had was Teflon spray ..the stuff made for snow shovels and snowblower from Dupont. This stuff is like naphta fluid very light and…slippery
            I sprayed the security bolt waited 30 seconds and the security nut spun right off the bolt… like butter
            Amazing stuff………….. it was or seems a lot better than PB blaster or Loose nut
            it crept right into the threads and bingo ….off with the nut !
            Hey I might even try it on stuck rings one day !
