’58 10 horse Johnson. Lower carb needle is stuck, even with the packing nut off. Is there a trick to backing the needle out without marring up the brass?
Update…just pulled the carb off the motor and opened it up. Had a rubber? gasket. White powder started falling out of it as I pulled the two halves apart. I’ll try to figure out how to post a couple pics so you can see what is left in the carb in a photo. Any idea what that is? I haven’t seen this before, but I’ve only done a couple outboard carbs.
Also, the saw-toothed piece that the filter sits on in the bottom of the glass bowl is really rusted. Is that a problem?
This topic was modified 6 years, 10 months ago by
cron78.
