Home › Forum › Ask A Member › Super Elto Coil Repair
- This topic has 5 replies, 3 voices, and was last updated 9 years, 1 month ago by
wbeaton.
January 31, 2017 at 5:15 pm #6242
If your looking for a Zephyr coil for your Super Elto
here are a couple. Note they are being sold separately.
Ask what "Tested" means and are the plug wire
connections tight to the coil.http://www.ebay.com/itm/1946-EVINRUDE-Z … 5f&vxp=mtr
January 31, 2017 at 5:53 pm #52213Hi Tub’s. I read about having tight plug wire connections before I did my coil conversion so I made sure to use one that was tight. However, I am unsure why its a concern. I have a second Zephyr coil that has slightly loose plug wire connections that reads over 7 ohms with the multimeter. Why are the loose connections a problem?
Wayne
February 1, 2017 at 2:11 am #52232That means the strap that holds them down is broken which can easily break the fine wire which is soldered to it. The spark can jump the gap for a while, but that eats into the insolation shorting out adjacent wires and reducing voltage. In other words, it may be the beginning of the end for the coil. . . 😕
February 1, 2017 at 2:46 am #52233That’s interesting. What causes the strap to break? I assume there is no way to secure the terminals.
PS. I like your signature, Garry.
Wayne
February 1, 2017 at 4:28 pm #52246quote wbeaton:That’s interesting. What causes the strap to break? I assume there is no way to secure the terminals.
Most common cause would be the plug wire being pulled on.
Your test would indicate that the wires aren’t broken – YET.
Vibration from running will cause them to break eventually.
The motor may still run for awhile as Gary has described but
eventually the coil will fail.
No way to re-secure the terminals.A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
February 1, 2017 at 7:17 pm #52258Good to know. Thanks. Maybe I’ll open up the coil and take a look inside since its not good anyway.
Wayne
