Home Forum Ask A Member taking bumps out of tn gas tank
  • #8624
      any easy way to pop out tank bruises on TN-JW style fuel tanks or am I stuck using Bondo filler and paint โ“
      Joining AOMCI has priviledges ๐Ÿ™‚
      #67129
      retiredoz
        Seems to me the old Johnson Service Manual had a section showing a compressed-air and torch trick. Disclaimer : I never tried it.
        #67132
        david-bartlett
          quote retiredoz:
          I have done this with a Bendix tank. I used about 8-10psi and a propane torch and had some success. Keep the heat moving.
          #67133
            sounds doable… I’ll somehow try pressurizing from the fuel valve threads and use a heat gun to start with …..getting cold outside and flame torching in the basement sets of alarms… ๐Ÿ˜ฎ
            #67135
              And of course there cannot be ANY GASOLINE FUMES present . . .
              ๐Ÿ˜†
              #67137
              Moxy
                I did the air pressure trick on a Lightwin and it worked great. It is VERY important to clean it well and eliminate any possibility of fumes. I added some pictures to a post (https://aomci.org/forum/viewtopic.php?f=2&t=10273&p=62683#p62683), and included the instructions from my fifties service manual, which is the best book I have ever read. :~)
                #67139
                stanley
                  On tanks like a JW,TD or HD,I found out the hard way it is best to keep them screwed to the "frame/bracket"they sit in.If you don’t,the air pressure can deform the bottom of the tank and it won’t fit into the bracket when you try to re-install it.
