Home Forum Ask A Member TD 20 Piston Rings Availability
  • #205933
    Mark Johnson
      Does anyone have a lead on where to find piston rings for a TD 20? The part numbers I have searched are 41-333, 041333 and 378432. Are their any other numbers to look out for?
      Thanks.
      Mark
      #205934
      lloyd
        I have some new ones in my shop. If you can’t find any easily on line contact me and we will see if we can fix you up. You will almost certainly also need new leather primer seals and instructions to replace them. I am the guy that makes them. Lloyd Lautner 231-929-7479
        #205986
        Mark Johnson
          Lyoyd
          Thank you very much for getting back to me. I will give you a call today. I’ve been looking for these for quite a while with no luck.
          Thanks again.
          Mark
          #206018
          lloyd
            Hi Mark. Fun talking with you on the phone today. I have plenty of the #378432 new ring sets still sealed in the original packets., and 5 of the 2 piece casted fuel tanks. Give me another call after you check the compression and the one way fuel valve to the low speed orifice as we discussed.
            #206449
            Mark Johnson
              Lloyd
              Nice chatting with you too. Should be able to do the compression check this week. Will let you know how that comes out. As for the cast tanks, that would be great. Better than trying to pull all the bumps and bruises out of the ones I have.
              Mark
              #206506
              lloyd
                Mark. I have a packet of the 378432 rings on my desk here. Give me a call whenever you are ready.
