Home Forum Ask A Member Teimpo Fuel 6 gallon Tank
  • #6702
      See your friendly local lawn mower shop.
      #55784
      gjonz
        Got mine on EBay. Direct replacement.
        Greg
        #55799
          If it’s the tank I think it is, make sure you also get a new gasket. The pick up assembly sits in a pocket on top of the tank. The gasket splits; then, when it rains, water goes right into the tank. Those tanks used to give us fits and we would switch them for something else, most of the time. When you cut them (with a HAND saw, not a spark-producing electric one!!) ) horizontally, they do make great drain pans…..
          #55804
          gjonz
            That a great tip er 2.
            Thanks!
            Greg
            #56229
            amuller
              quote BillW:
              IMO these tanks suck (water, literally). As noted, the pickup sits in a pocket on the top of the tank and tends to rotate and loosen. It’s not obvious to me how to make a reliable seal. Anybody know? (I think the tanks are polyethylene and nothing will reliably stick.)
              #56238
                Sure they warp, crack and leak, but they are guaranteed not to rust. . . 😆
                #56257
                amuller
                  I got a 6 hp Johnson that had water in the pump, the lines, the crankcase, the carb…. Rusted up and basically ruined. It didn’t seem that submergence was the story. I was puzzled until I looked closely at the plastic tank it came in with. A nice little motor ruined and I doubt the people who had it ever knew why.
