Home Forum Ask A Member Test Results
  • #8283
    brian
      After all the testing, tweaking, and fiddling around with these three motors here are the results of running them on the same boat rated for 16 hp, load, lake and similar weather conditions. Scott Atwater literature claims 30 mph on the 16 hp. That seems a bit optimistic.
      1955 Firestone 16hp
      19 cubic inches
      4200 rpm indicated
      9 x 9 prop
      23 mph on 14′ aluminum boat
      1952 Evinrude 4441 14hp
      19 cubic inches
      4000 rpm indicated
      9 x 10 prop
      21 mph on 14′ aluminum boat
      1974 Mariner W15hp
      15 cubic inches
      5500 rpm indicated
      9 x 9 prop
      https://www.youtube.com/channel/UCzXzvw … qBA/videos
      #65215
        I’m surprised that Evinrude did so well!
        #65219
        brian
          That Evinrude is one gutsy motor. Definitely my favorite of the three. Does everything asked of it from idle to top speed. My video of the high speed run messed up during rendering. I hope to get back out and film it.
          #65237
          wbeaton
            Cool. I love real world results. Test and tube days are my favourite.
            Wayne
            Upper Canada Chapter
            uccaomci.com
            #65240
            opposedtwin
              So, it looks like more horse power and less pitch = more speed. At least among these three.
              #65244
              brian
                It took the Mariner an extra 1300 – 1500 rpm to keep up with other two. It was working real hard to get there. The Evinrude was impressive at top speed only turning 4000 rpm and didn’t sound like it was working too hard. It would be interesting to try a 9 x 9 on the Evinrude. The manual says it runs 4000 to 5000 rpm. An extra grand would certainly show the Firestone who’s boss.
                #65245
                squierka39
                  I can agree with your sceptidism on tne Scott Atwater/Firestone. I have 1956 16hp Scott and a 1956 Evinrude 15hp Fastwin. On my Duranautic 13 ft aluminum boat the Scott goes about 22mph and the Evinrude is close to 25mph.
                  Good data, thanks for sharing.
                  #65246
                  brian
                    I need to do a search as to why the 19 cubic inch Evinrude is only rated at 14hp. The rpm range would certainly support a higher rating and it doesn’t feel like it is at it peak running at 4000 rpm. Garry probably has the answer 🙂
                    #65247
                      The 4441 Fastwin was a souped up Elto 12 and a stop gap to the 20 cubic inch class while they worked on a more modern replacement – the 15012 Super Fastwin of 1953, It is a big improvement. , , 😀
                      #65248
                      brian
                        Thanks Garry. The 4441 has some serious compression when pulling the starter. The other two not so much. While it might take a little more effort to get to the powerhead, it certainly is robust and feels solid.
