Home Forum Ask A Member testing coil on a 1949 Johnson OK20
  • #279730
    Chuck Beck
      HI All
      Recently aquired what I believe to be a 1949 OK20 Johnson,( from what I see same as an OK15 but with removable heads) wanting to know how to check this  motor’s coil? and what good readings might be ?
      Many Thanks  Chuck
      #279773
      stanley
        I assume there is only one coil with two plug wires.Disconnect all wires from coil to plugs,points,condenser and ground.Test secondary by checking ohms between tabs where plug wires attach to coil.Should be about 8,000 ohms.Next test primary between wire to points and ground wire,should be less than 1
        #279803
        Chuck Beck
          Thanks Stanley ! much appreciated ! Looks like I need a new one ! Cheers
          #279866
          George Emmanuel
            I think the OK coil is the same as a PO, so it should be easy to find.
            George
            #279873
            stanley
              Here’s list of models using same coil
