Home › Forum › Ask A Member › Testing condensers question
- This topic has 4 replies, 3 voices, and was last updated 2 years, 11 months ago by
jeff-register.
April 29, 2023 at 11:38 am #275735
I’m checking a bunch of condensers and getting some results I don’t understand.I am electrically challenged and the tester is cheap but here are pics showing result for one rated .22 mfd.I assume the two readings should be nearly the same and just have the decimal point in a different place?
April 29, 2023 at 1:00 pm #275743the only good way to test condensers is aside from obvious shorts, dead, no reading…. with a VOM and Cap meter is to measure under load at 250V +
see M.Mohat’s excellent articles on the subject and offer …if you write to him …..to supply you with a a basic test box diagram you can build… I did and it works great
https://wrcoutboards.org/wp-content/uploads/2020/04/Part1_Condenser_Construction_Failure_Modes.pdf
https://wrcoutboards.org/wp-content/uploads/2020/04/Part3_Sizing_Condensers_Correctly.pdf
https://wrcoutboards.org/wp-content/uploads/2020/04/Part4_Repairing_Broken_Condensers.pdf
April 29, 2023 at 2:00 pm #275749These are all condensers which have passed the test under load on my Graham Lee coil and condenser tester.The problem is when I test for the actual capacitance value of the condenser.The readings I get do not make sense. I assume that the values for two different “scales”should be equivalent for the same condenser,but they are not.I would like to know why they might not be.
April 29, 2023 at 3:38 pm #275750different scales may…. apply diff test voltages on the probes which may or may not charge the capacitor to saturation…causing diff. readings.
with another meter you could try to measure the cap. testing voltage on different scales.
April 30, 2023 at 11:59 pm #275777Capacitors, not condensers should have a very high volage rating, a fast charge/discharge rate & high dielectric rating. Your old caps are more than likely bad because the dielectric value has failed. I’ve never used the caps in “repairing caps” web page but the dielectric constant is very good. Please grt new caps to save headaches.
