Home Forum Ask A Member Testing Cut-out Switch
  • #10422
      I was wondering at what vacuum are the OMC Cut-out switches from a 1955
      RD-17 suppose to operate / ground the ignition?
      I have one I’d like to test to see if it’s operational, but I don’t
      find any testing data anywhere.
      I don’t have a vacuum pump, but could run a hose to my Chevy carb
      if the vacuum isn’t too high for the cut-out switch.
      Thanks.
        Um—bear with me, I’ll have to see if I can find that spec. I know that 25-30-35-40hp motors have various specs.
        EDIT: The Johnson service manual goes into great detail as to how it works, but doesn’t say at what vacuum. It only says that it should operate if running 2000 RPM in neutral and suddenly closing the throttle. Yeah, and if it doesn’t operate, you got a runaway motor on your hands. Cool.
        #78780
        William Jatzek
          You can just put a piece of vacuum hose on it and just put the hose in your mouth and suck on it and use an ohmmeter to check from the terminal to the body to see if you have continuity when applying vacuum. The spring inside is specific to the engine year so do not use one from another year engine.
          #78781
            quote FrankR:
            Frank, I presume that if I could indeed test the vacuum switch via "mouth"
            as Billy suggest, then the diaphragm most likely would be good yet,
            and perhaps no further testing would be required at a specific vacuum.
            It would be nice to know what the official procedure was suggest by OMC.
            Last time I tried vacuum testing something via mouth I got dizzy, lol.
              I’ve tested them by mouth. Was dizzy before and still am
              #78785
              nj-boatbuilder57
                but testing by mouth doesn’t confirm what spring rating you have. It only confirms that a.) the diaphragm is good, b.) the switch is good, and c.) that your mouth muscles are strong enough to overcome the spring.
                Need a vac meter & the specs….
                #78798
                  quote NJ-boatbuilder57:
                  Found this information from this old thread after searching via Google.
                  It’s regarding Gales outboard, but presume it’s similar to it’s cousins.
                  viewtopic.php?t=3415
                  I don’t think I can suck that hard 😮
                    Just learned that "Inches of water vacuum" and "inches of Mercury (Hg)
                    are two different animals.
                    42 to 46 inches of water equates to 3.1038 to 3.3994 inches of Mercury.
                      Gale manual??!! Heck that is where I intended to go in the first place, but thought the Johnson one would be more comprehensive. Fooled again.
                      #78809
                        Any reason why one of these budget "brake bleeder" hand
                        held vacuum pumps wouldn’t work for testing cut-out switches?
                        I’ve been wanting one for the past 30 years for bleeding brakes
                        anyway….. of course now, I hope my brake bleeding
                        experiences are about over!
                        https://www.ebay.com/itm/Car-Hand-Held- … SwWLFZo6z0
