Home › Forum › Ask A Member › Testing voltage to the points on the Sportfour Imperial
- This topic has 16 replies, 4 voices, and was last updated 3 months, 2 weeks ago by
Tubs.
October 28, 2025 at 2:35 pm #301017
Have my voltmeter hooked up directly to one set of points on this battery
ignition Evinrude. It’s running just under 10 volts, which still seems high,
as I’m now using a 3 ohm resistor before the ignition coil.
Not sure what to believe.VIDEO……..
October 28, 2025 at 8:48 pm #301027I am no expert on your engine type but… JMHO…..if you measure voltage on or across point that open an close the voltage will be at max value during the open air gap of the point because by ohms law….. the highest voltage appears at the highest resistance point (air gap) of measurement in a series circuit.
your meter is only showing you a value made up of PEAKS ( when the gap opens) and something (when the gap closes)
analog or digital meters are to slow to react (damper) to these fast fluctuations and the only way to “see” what you have is with an oscilloscope..
if you feel adventurous Amazon has lots of inexpensive scopes below 75$
October 28, 2025 at 10:55 pm #301029Interesting Crosbyman, but I think in my case, that scope would be a little
bit of an overkill.Prepare to be boarded!
October 29, 2025 at 12:12 am #301031agree the one in the utube is to much $$$$$ but a small inexpensive single trace scope is all you need for OB work . up to you.
October 29, 2025 at 8:52 am #301039Regards to “overkill”, I’m not referring to the price, but
rather that it would seem like using a $1000 gold plated
toilet seat, when the Ohm’s Law should tell me what
size resistor I need.
I just don’t think I have quite the right information in
my calculations perhaps?With the current volts to the points with the engine running,
V=IxRI have, between the ignition resistor and primary coil resistance (3 + 1.3)
around 4.3 ohms, and if the voltage to the points is running just under 10 volts,
that calculates to an amperage of 2.3 amps current.2.3 amps x 4.3 ohms = 9.89 volts, about what I currently have at the points.
When I tried using the 2 ohm ignition resistor, and having a total resistance of
3.3 ohms, the current must have ran at a higher amperage. During that test,
I checked voltage at the coil “Bat” connection, and was running 11 volts,
but in testing at that location, it’s not taking into account the resistance
of the primary coil……. hence, my two test weren’t “apples to apples”.Then there’s the question, do I calculate the primary resistance of both
coils in the coil tube for my equations, or just the one? I only did
the one.With all my calculations, I’m stumped why, when using a 3 ohm ignition
resistor, I’m still getting almost 10 volts to the points!Prepare to be boarded!
October 29, 2025 at 11:39 am #301050Do you know if there is an IDEAL voltage to the coils? I know the ballast resistors in the Chryslers was used because of the oil filled metal can coils that would get hot. Is it possible that the ballast resistor is there to just regulate the voltage to the coils because of the voltage fluctuation with the generator voltage? I don’t know and I am just questioning what the voltage should be.
October 29, 2025 at 5:35 pm #301051From what I know, points ignition systems with 12 volt systems,
had a ballast resistor, or other type, usually around 1.7 ohms,
depending on the type of coil used. This was to lower the voltage,
and hence the current going through the points so they didn’t
burn up.
The generator will change the equation somewhat I presume,
when it’s putting out 13.5 volts, etc.,
I read somewhere that nine volts to the points would be okay,
but I’m currently at 10 volts.Prepare to be boarded!
October 29, 2025 at 9:49 pm #301064I am not certain V=IxR because current in a coil is not a simple curent flow as in a plain old resistance .
A “coil”offers not only the pure wire resistance it actually opposes the flow of current because of its inductive resistance.
gets tricky to make current calculations because the formula is a tad more complex .
If I recall….. in a capacitor …current actually moves faster while voltage follows later.
In a coil voltage rises faster while current is held up by the magnetci build-up in the coil (inductive reactance)
lots of good articles on the net on the subject…
that said play safe & just reduce the current to protect points and coils while producing a good enough spark on the plugs.
jmho
October 29, 2025 at 10:48 pm #301069I seen a video earlier regarding cars, that said to measure the ignition voltage
(with the engine off) with the volt meter hooked up to the coil “Bat” side,
and have the other side of the coil grounded.
That would tell you how much the ignition resistor is dropping down
the voltage, but I presume one would only want to do that test
for an instant or risk blowing the coil?Prepare to be boarded!
October 30, 2025 at 8:12 am #301073What about using a dual ballast resistor like the Standard Ignition RU-12. I believe one side is approx. 5 ohms and the other side is approx. 1.2 ohms. You could use the 5 ohm side and if needed, add the 1.2 ohm in series. Just a thought. They are not too expensive.
