Home Forum Ask A Member The infamous MDH 4001M
  • #258286
    Nicholas Keller
      Is there a direct replacement for this starter that screws into the bracket without modification. The bracket is off a 1956 evinrude fastwin and installed on a  1070 Johnson 25. I don’t care if it is 6 or 12 v just don’t want to get another bracket or modify the existing one. Unfortunately regarding this cursed Autolite MDH 4001M all the information I have come across is either useless, inaccurate or completely contradicts the last thing I have read about it.
      #258288
        I believe that starter is a 6 volt model and that bracket has a 2-1/4″ bolt spacing for the starter mount bolts.   As far as I know, all modern 12 volt starters have a 2-1/2″ bolt spacing, so a 12 volt starter will not mount up on the 1956 bracket.  If you don’t want to replace the bracket, you’ll have to somehow find another 6 volt replacement starter or if you already have a 4001M that doesn’t work, get that starter rebuilt.  You can run a 6v starter off a 12v battery, just for shorter bursts.
        • This reply was modified 3 years, 11 months ago by Bob Wight.
        #258364
        Nicholas Keller
          That sums it up pretty clearly. I have yet to ascertain the starter that I have as far as function is concerned. Having clarity on the matter is nice just so I know what is what before doing so is helpful. I am cautiously optimistic but fully realize that there is a high likelihood I might have a 6 pound paper weight.
