Home Forum Ask A Member They ran great in the barrel at home.
  • #277428
      After 5 days, got a bit of time in between
      showers to get the motors together.
      Didn’t have the nerve to go out as I didn’t
      want to get them wet!!!!!!
      Finally ,a break in the weather and
      their on the boat.
      As usual, they ran great in the barrel at home but—
      rain is back so I’m burn up time editing some video.
      Link – https://youtu.be/53yTD4zf17c
      #277432
        The little “Pal” may have some running issues, but it sure looks nice,
        as well as that Evinrude that we want to see running too!
        I rarely have a “first time” motor test on the boat go 100%……
        usually something stupid like a plugged gas cap vent, etc.
          Beautiful motors, beautiful lake.   I’m sure you’ll get the Pal running smooth.   Can’t wait to see the Evinrude rolling smoke!
          #277623
            https://youtu.be/3BVbHBJSHgk
            #277626
            reivertom
              I once had a ’56 Scott Atwater 5hp that was beautiful, but was allergic to lake water. It would run fantastic in a barrel, but every time I put it on a boat, it would not start up after the first run down the lake, thus making a long paddle back. I gave up and gave it away to another sucker….I didn’t have the heart to sell it for good money. I hope you have better results..
              #277907
              billy-t
                Those are beauties!
                3 users thanked author for this post.
                #277934
                JOSEPH BRINCAT
                  Tubs, thanks for posting… beautiful motors on a beautiful lake,
                  As you are likely aware, with the small motors, crankcase compression is particularly important for good slow speed running. Think that could be the issue with the Pal?
                  #277937
                    I’m certain it was just that. I had the motor
                    apart, in a container, for several weeks to before
                    it spent 3 days traveling in the back of a pickup.
                    As the crank shaft was out of the lower main
                    bearing the oil that makes the seal was lost. Once
                    that oil was replaced, from running, the starting issue
                    went away. As usual, my attempt to clean the gas
                    tank wasn’t totally successful. I struggled with that
                    for a bit but I have run just over a gallon of gas
                    through it now and its doing really well.
                    Now it’s time for some performance upgrades.
                    Here is another video. – https://youtu.be/3BVbHBJSHgk
                    #277938
                      That’s one mean looking Elto Tubs.
                      Did it have that exhaust pipe on it when
                      it was running in the video? If so, much quieter
                      than I would have thought.
                        Not on it in that video but I have some.
                        I need to edit it and change the format-
                        weather permitting.
                        Up loading here takes a while here too.
                        I don’t want to spend the time on it if its nice.
