Home Forum Ask A Member Thoughts on the brass shear pin and the monel drive pin for OMC engines
  • #298369
    William Jatzek
      For many years on my mid 50’s Big Twin engines I used brass shear pins made from 1/4 inch brass brazing rod with no issue. If I hit something with the propellor the brass would shear with no damage to the motor. I know the 1956 Johnson 30 HP. calls for a drive pin and I think it’s made of monel metal.  Something like stainless steel. A friend of mine with a 1958 Johnson 18 HP. had a monel pin in his motor and hit something and now the lower unit has an internal problem and the pin bent but did not shear. I would like some opinions on using brass or the monel drive pin.
      #298370
      Waunnaboat
        US Junior Member
        Regardless of whether or not they call for a brass pin, if it has worked and sheared when necessary, I would continue going with a brass pin.  I prefer to err on the side of caution whenever possible in any field of life.
        #298373
        JOSEPH BRINCAT
          For what we typically do with our hobby motors… like no transatlantic voyages, go with brass on the larger motors. I even use aluminum shear pins on the small put -puts.
