I’m pretty sure it’s a #10 screw but I don’t remember it being a fine thread. Hopefully someone knows for sure but I’m thinking it’s #10-24 UNC. I certainly could be wrong. Dan Anderson would likely know from memory.
-Ben
When you put that heli-coil in, make sure the end of it is flush, or just below that flat surface, because your waterpump will no work correctly if the wear plate is not sealed to that surface properly.
