Home Forum Ask A Member ThreeBond Products
  • #296452
    LARRY CATON
      Does anyone have experience with using a ThreeBond product in place of 3M-847 ?  For example, to seal crankcase halves or hold spaghetti seals in place while assembling gearcases?  https://threebond.com/
      I’d never heard of ThreeBond, but saw it mentioned multiple times on motorcycle forums.  Apparently,  Yamaha, Honda, and others have sealants called YamaBond, HondaBond, etc. that folks say are re-branded versions of a ThreeBond sealant.
      I contacted ThreeBond by completing a form on their website.  They responded within an hour, but I feel like their Sacramento, CA representative is giving me the runaround.  I asked if they could recommend a product for sealing crankcases, and he replied that they can’t and I should follow OEM recommendations.  I wrote back saying that OMC is out of business, and I need a sealant comparable to 3M-847.  He said that they don’t have a cross reference for 3M-847.  Geeesh!
      Finally, I said that I need a low viscosity sealant, resistant to oil and gasoline, suitable for assembling crankcases without a gasket, preferably with an open time of several minutes to allow for positioning and assembly.  I decided to post here while I wait for a response.
      1956 Johnson 15 Hp, FD-10
      1957 Johnson 5.5 Hp, CD-14
      1958 Johnson 5.5 Hp, CD-15
      #296455
        would  permatex aviation sealer  work  ?
        Permatex 80019 Aviation Form-A-Gasket No. 3 Sealant, 4 oz. : Amazon.ca: Automotive
        #296456
          I’ve never used them but Threebond products have been around for a good while and they are commonly used for sealing crankcase halves.   They would work as an outboard crankcase sealer but if it’s a straight metal joint with no spaghetti seal, then I typically use Permatex anaerobic gasket sealer on my OMC motors.    It works great and is a lot easier to use than the sticky, gooey, messy 3M847.    The 847 can be used on crankcase halves that use a spaghetti seal but not a straight metal to metal joint.  I also used Permatex Moto-Seal to seal the crankcase halves on an Evinrude motor – it’s very similar to the Threebond products.
          For sealing OMC gear cases, I recommend Permatex Ultra Black.   It’s WAY easier to use than 847 and seals just as well.
          #296469
          labrador-guy
            I am with bob on this post.  Those new silicone base sealers are great!  The bigger the glob the better the job?  Not!
            dale
            #296504
            fifty20ne
              IMG_1608
              IMG_1609
              Most snowmobile guys use Threebond
              On crankcase halves “Good Stuff!”
              and recommended by John at
              Nutters Speed Shop.
              https://youtu.be/Q6OOup4vEqM?si=7qi3Ap33seRNS-dU
              #296507
              fifty20ne
                IMG_1608-1
                IMG_1609-1
                Nutters Speed Shop.
                #296842
                LARRY CATON
                  I’ll try the Permatex anaerobic sealer next time I split open one of the Johnson CD crankcases.
                  I used the Ultra Black on a spaghetti seal gearcase.  It worked well and was easy to apply.
                  #296844
                  LARRY CATON
                    Thanks Bob,
                    I’m new to the game and haven’t used most of these products.  When I was a teen in the 70s the Indian Head gasket sealer was the only thing I used regularly for automotive gaskets.  Then they came out with the RTV silicone products.  I don’t know if I did something wrong, but back then I used the RTV on oil pans and valve covers with mixed results.  Now, there’s a huge variety of RTV products and I had lots of success with them when I owned a 1972, 120 Hp OMC sterndrive.  The high heat version worked well on the exhaust manifold gasket and saved me a trip to the machine shop.
                    I saw on the Three Bond website that they too have an anaerobic sealer that’s intended for metal to metal flanges. I thought the sales rep would’ve steered me that way but he ghosted me.
                    #296846
                    LARRY CATON
                      In the snowmobile video they used Three Bond 12-11.  It’s an RTV that from the datasheet (attached) seems capable of forming thin films with good performance in the applicable temperature range, chemical resistance, and blow out pressure.
