Home Forum Ask A Member Throttle closes Johnson 3 HP Jw 12
  • #275739
    Francis Cyr
      There must be a way to adjust the tension on the throttle.  While the motor runs the throttle lever slowly moves to the slow/stop position.  I don’t see a way to adjust the tension other than to bend the lever so it rubs against the cover.  Thanks.
      #275740
        wave washer installed…. ??    try bending it a bit carefully … it is used for that pur pose. see parts layout
        download yourself a copy of the JOnson service manual
        MEMBERS ONLY TAB
        INNER SANCTUM
        LIBRARY
        find GARRY SPENCER’S DROP BOX go down his list find …..RED BOOK
        Download and print
        #275742
          Are you sure the flywheel magnets are not rubbing on the coils?  If so, the throttle will be dragged towards the stop position
