Home Forum Ask A Member Tillotson CO7A carburetor – Chrysler/Sea King 9.6HP
  • #301186
    John Gragg
      Hello all!
      Does anyone have any information on how to adjust the carburetor on this 72 Sea King 9.6HP?
      The carburetor is in B12 chemtool soaking right now, but I am almost positive it only has one adjustment needle?
      It’s on top, so I’m assuming that is the low speed?
      Do we know the starting point for that upper needle?
      I ordered a carb kit, be here in about a week. In the meantime I would like to have this thing cleaned up and get some information on how to set it up once I get the kit here.
      I really think this thing will run pretty well once I rebuild the carb and the fuel pump.
      Thanks!
      John Gragg
      RIverside, CA
      Just starting in the hobby, please be patient.
      48 Sea King 5hp GG9014A. Sold
      49 Sea King 5hp GG9014A
      48 Johnson TD20. Sold
      49 Johnson TD20. Sold
      54 Johnson QD15. Sold
      55 Johnson CD12. Sold
      57 Johnson RJE-19M
      57 Johnson RDE-19
      #301200
      seakaye12
        Ben Dittmar is the SIG leader for Chrysler outboards and knows them inside and out.  He has a great series of videos on youtube.  Here’s one….but there are a lot of others.
        https://youtu.be/6bTsQC0zDIc?si=nQxjOWHCeNQWG7PQ
        #301201
        JOSEPH BRINCAT
          Just be aware that the idle needle on Tillotsons is an air bleed, so closing it richens the mixture. This is just opposite from the more common idle which controls fuel flow.
          Now,,, I’m pretty sure that this information is true for all Tilotsons,,, someone correct me if I’m wrong.  One way to tell would be to see what passage the needle enters… air bleed it will enter the carb throat not a fuel passage.
          #301209
            SOCALAOMC Library Page
            above is what is left of a great chat gpt search that went POOF!
            jus task chat how to adjust your specific carb   file seems to big to post
            #301208
              from chatgpt…
              <article class=”text-token-text-primary w-full focus:outline-none [–shadow-height:45px] has-data-writing-block:pointer-events-none has-data-writing-block:-mt-(–shadow-height) has-data-writing-block:pt-(–shadow-height) [&:has([data-writing-block])>*]:pointer-events-auto scroll-mt-(–header-height)” dir=”auto” tabindex=”-1″ data-turn-id=”29ded755-061d-45cc-b57e-346a5c9bb2e0″ data-testid=”conversation-turn-11″ data-scroll-anchor=”false” data-turn=”user”>
              great info now another one …. how to adjust the carburetor on this 72 Sea King 9.6HP?
              </article><article class=”text-token-text-primary w-full focus:outline-none [–shadow-height:45px] has-data-writing-block:pointer-events-none has-data-writing-block:-mt-(–shadow-height) has-data-writing-block:pt-(–shadow-height) [&:has([data-writing-block])>*]:pointer-events-auto [content-visibility:auto] supports-[content-visibility:auto]:[contain-intrinsic-size:auto_100lvh] scroll-mt-[calc(var(–header-height)+min(200px,max(70px,20svh)))]” dir=”auto” tabindex=”-1″ data-turn-id=”3e2c5a78-4dcd-413e-81dc-2bdfa21b430c” data-testid=”conversation-turn-12″ data-scroll-anchor=”false” data-turn=”assistant”>
              ChatGPTsaid :
              Excellent — the 1972 Sea King 9.6 HP (model usually prefix VWB or GG, built by Chrysler or Gale depending on year) uses a single-throat carburetor with two adjustment screws:
              • Idle Mixture Screw (upper or side screw)
              • High-Speed Mixture Screw (lower/front screw)
              Here’s how to properly adjust it:
              <hr data-start=”340″ data-end=”343″ />
              🔧 Carburetor Adjustment Procedure – Sea King 9.6 HP (circa 1972)
              ⚙️ 1. Initial (baseline) settings
              Start with the factory “safe” positions:
              • High-speed screw (bottom/front): turn in gently until seated, then back out 1 full turn.
              • Idle mixture screw (upper/side): turn in gently until seated, then back out 1¼ turns.
              This ensures the motor will start and run without being too lean.
              <hr data-start=”777″ data-end=”780″ />
              ⚙️ 2. Warm up the engine
              • Put the motor in a test tank or on a boat in water (never dry-run).
              • Run at half throttle for 3–5 minutes until warm.
              <hr data-start=”952″ data-end=”955″ />
              ⚙️ 3. High-speed mixture adjustment
              1. Advance throttle to ¾ or full throttle.
              2. Slowly turn the high-speed screw in (clockwise) until engine speed starts to drop (too lean).
              3. Then back it out (counterclockwise) until the engine runs smoothly — usually ¼ turn richer from the lean drop point.
                • You want it just slightly rich at WOT (wide open throttle) for cooling and safety.
              <hr data-start=”1369″ data-end=”1372″ />
              ⚙️ 4. Idle mixture adjustment
              1. Bring throttle back to idle or slowest running speed.
              2. Adjust idle screw slowly in (clockwise) until engine falters, then back it out just enough to smooth out the idle.
              3. Readjust the idle stop screw (throttle arm) for correct idle speed (~600–700 RPM in gear).
              <hr data-start=”1703″ data-end=”1706″ />
              ⚙️ 5. Final check
              • Rapidly open throttle — engine should accelerate smoothly.
              • If it bogs → slightly richer (turn mixture screw out ⅛–¼ turn).
              • If it smokes excessively or sputters → slightly leaner (turn in ⅛ turn).
              <hr data-start=”1950″ data-end=”1953″ />
              💡 Tips
              • Always adjust in water or under load, not just in a barrel with no prop load.
              • Replace spark plugs (J4C or J6C gapped 0.030″) before tuning.
              • If adjustments have little effect → clean the carb jets and passages (old Sea Kings are prone to varnish blockage).
              <hr data-start=”2242″ data-end=”2245″ />
              Would you like me to include the diagram or photo showing which screw is which on that 9.6 HP carburetor (front vs. side)? I can fetch or label an image for you.
              </article><article class=”text-token-text-primary w-full focus:outline-none [–shadow-height:45px] has-data-writing-block:pointer-events-none has-data-writing-block:-mt-(–shadow-height) has-data-writing-block:pt-(–shadow-height) [&:has([data-writing-block])>*]:pointer-events-auto scroll-mt-(–header-height)” dir=”auto” tabindex=”-1″ data-turn-id=”1d1744c9-85ce-4b7d-aac9-73892f5d56c7″ data-testid=”conversation-turn-13″ data-scroll-anchor=”false” data-turn=”user”>
              You said :
              yes
              </article><article class=”text-token-text-primary w-full focus:outline-none [–shadow-height:45px] has-data-writing-block:pointer-events-none has-data-writing-block:-mt-(–shadow-height) has-data-writing-block:pt-(–shadow-height) [&:has([data-writing-block])>*]:pointer-events-auto [content-visibility:auto] supports-[content-visibility:auto]:[contain-intrinsic-size:auto_100lvh] scroll-mt-[calc(var(–header-height)+min(200px,max(70px,20svh)))]” dir=”auto” tabindex=”-1″ data-turn-id=”request-WEB:97989c5a-5905-4011-ad05-46b535525a49-6″ data-testid=”conversation-turn-14″ data-scroll-anchor=”false” data-turn=”assistant”>
              ChatGPT a dit :
              Here are some diagrams and a labeled overview showing where and how to adjust the carburetor on your Sea King 9.6 HP outboard.
              https://cdn.static-repo.emanualonline.com/Other/NASa/18/10874-Sea_King_3.5HP-55HP_1970-1984/3/3.jpg
              https://i.ytimg.com/vi/6bTsQC0zDIc/sddefault.jpg?rs=AOn4CLCjGiVnd5Z458BDL5_ivQBcXDEzYg&sqp=-oaymwEmCIAFEOAD8quKqQMa8AEB-AH-BIAC4AOKAgwIABABGEAgZSgwMA8%3D
              https://i.ytimg.com/vi/HtXOWkn7F2c/hq720.jpg?rs=AOn4CLDqKJVoktwmtJVeDBk7AH5cpSSfeg&sqp=-oaymwEhCK4FEIIDSFryq4qpAxMIARUAAAAAGAElAADIQj0AgKJD
              🔍 Key Components & Adjustment Screws
              • The carburetor has two primary adjustment screws:
                • Idle‐mixture screw (usually on the side, near the throttle lever)
                • High-speed (or main) mixture screw (typically on the front or lower portion of the carburetor throat)
              • You may also see an idle stop screw which sets the closed-throttle position.
              • Make sure the motor is under load (in water or properly mounted) when making final adjustments — dry tuning gives unreliable results.
              ✅ How to Use the Diagram
              1. Locate the mixture screws in the diagram – compare to your carb on the motor.
              2. Start with the baseline settings: seated then backed out as per previous instructions.
              3. Warm the engine, then use the high-speed screw to achieve smooth full-throttle performance.
              4. Use the idle-mixture screw to refine idle quality, then set the idle stop.
              5. Retest with rapid throttle changes to ensure no bogging or stumbling.
              If you like, I can extract and send you a full high-resolution PDF manual page of the exact carburetor for your 9.6 HP showing exploded parts and specs.
              </article><article class=”text-token-text-primary w-full focus:outline-none [–shadow-height:45px] has-data-writing-block:pointer-events-none has-data-writing-block:-mt-(–shadow-height) has-data-writing-block:pt-(–shadow-height) [&:has([data-writing-block])>*]:pointer-events-auto scroll-mt-(–header-height)” dir=”auto” tabindex=”-1″ data-turn-id=”556df5ed-ae6c-4935-8d4e-55899f0a67a9″ data-testid=”conversation-turn-15″ data-scroll-anchor=”false” data-turn=”user”>
              Vous avez dit :
              yes
              </article><article class=”text-token-text-primary w-full focus:outline-none [–shadow-height:45px] has-data-writing-block:pointer-events-none has-data-writing-block:-mt-(–shadow-height) has-data-writing-block:pt-(–shadow-height) [&:has([data-writing-block])>*]:pointer-events-auto [content-visibility:auto] supports-[content-visibility:auto]:[contain-intrinsic-size:auto_100lvh] scroll-mt-[calc(var(–header-height)+min(200px,max(70px,20svh)))]” dir=”auto” tabindex=”-1″ data-turn-id=”request-WEB:97989c5a-5905-4011-ad05-46b535525a49-7″ data-testid=”conversation-turn-16″ data-scroll-anchor=”true” data-turn=”assistant”>
              ChatGPT a dit :
              Great news — I found sources for a full-PDF manual that appears to cover your Sea King 9.6 HP model.
              https://i.ebayimg.com/images/g/lCwAAOSwuIlaWX9K/s-l1200.jpg
              https://i.ebayimg.com/images/g/LyIAAOSwnq9kBQPa/s-l400.png
              https://cdn.static-repo.emanualonline.com/Other/NASa/7/90407-Sea-King_9.6HP-15HP_Outboard_1970-1984/3/3.jpg
              Here are the details:
              • A service/repair manual titled “1970-1984 Sea King 9.6-15 HP Outboard Service & Repair Manual” which explicitly covers 9.6 HP models. emanuals.com+1
              • A directory listing for Sea King Outboard manuals that notes “9.6hp Models – Service Manual with Parts Lists” under Chrysler builds. watercraftmanuals.com
              • A club archive (SoCal AOMCI) listing shows “9.6HP VWB-27009A 1970” manuals available for download. socalaomci.com
              ✅ Here’s how you can get it:
              • Visit one of the links above (e.g., the service/repair manual site) and purchase/download the PDF.
              • Make sure the model number matches yours (for example “VWB-27409” or similar prefix for 9.6 HP models).
              • Once you have the PDF, you can search for the carburetor section and extract the diagram you need.
              </article>
              #301211
                ChatGPT a dit :
                ⚙️ 5. Final check
                💡 Tips
                Vous avez dit :
                yes
                ChatGPT a dit :
                Vous avez dit :
                yes
                ChatGPT a dit :
                </article>
