Home Forum Ask A Member timing adjustment tool
  • #5534
      sorry my memory is soft this am
      which member makes those flat pointed timing bars that sit on top of the motors allowing precise ajustement of the points..on 50s-60s e&j engines
      please indicate the price !
      #46188
      cajuncook1
        Frank Robb and they are very reasonably priced.
        http://www.franksoutboardtools.com
        #46196
        ADAM GIBB
          You can come and borrow mine if you won’t need it on a regular basis. Frank’s are more precise than the OMC ones that I have.
          Not trying to talk Frank out of a sale…just offered since you are nearby.
          Adam
          #46199
          fisherman6
            I have Frank’s timing fixture for the 5-18 hp OMCs and I have found it to be a worthwhile investment if you regularly work on these motors. With the right setup it is faster and more precise to use than a feeler gage. I have done enough tune ups on these and other engines that setting points with a feeler gage is fairly quick and I can get good results, but even then I find one off a bit if I go back and check it with the fixture.
            Is the fixture necessary to get a good running motor, no. To me is is a time-saver and you know you have set the points for optimum performance. It removes the guesswork from setting the timing exactly 180 degrees apart. That gives the best possible idle quality.
            -Ben
            OldJohnnyRude on YouTube
            #46209
              I have the original OEM tools, and I have Franks. I use Franks every, and keep the originals packed away in a box. there is no comparison in quality.
              #46248
                thanks for replies and offer
                Adam …see PM
                email sent to FR
